Home › Forums › Products › Stompboxes › Trouble setting up TF to control MF › Reply To: Trouble setting up TF to control MF
#130224
Hi Alan,
I hookt up a Midi
pedal board -> Modfactor-> NovaDrive (from TC) By
Midi
Everything works well.
But:
The NovaDrive has only
18 presets and  doesn’t have Prog. Chance Mapping
So i want to use the
 XMT
MIDI Transmit Channel
Control from the Modfactor to control one of those 18 Presets to the
Novadrive
I
did:
– Set the MIDI
Transmit Channel  –  ch1 NovaDrive also at ch1
– i Create a MIDI
Program Change Transmit Map  for example 13.1 > 1,   13:2
>2…..
– MIDI Program Change
Transmit Enable – on
– MIDI Transmit/Thru
Select – XMT
So now if i choose a
preset on my pedal board the ModFactor does the same as before (thats ok), but
the Nova Drive doesn’t do
anything.
ONLY, if i hit a
Button ON the ModFactor (in bank
mode), the NovaDrive chance to the desire preset.
What do i do wrong,
I just want to control
everything by my pedal board
Thanx in
advance
Rik
