Home › Forums › Products › Stompboxes › Trouble setting up TF to control MF › Reply To: Trouble setting up TF to control MF
September 25, 2009 at 3:22 pm
#130227
Hi Rik,
You can only have one MIDI controller at a time unless you get a MIDI merge device.
If you want ModFactor to change NovaDrive presets, keep the setup as-is.
If you want your MIDI pedal board to change NovaDrive presets then set ModFactor's MIDI Transmit/Thru Select to THRU. (ModFactor will no longer change presets on NovaDrive but MIDI pedal board will.)
