Home Forums Products Stompboxes Trouble setting up TF to control MF Reply To: Trouble setting up TF to control MF
#130235
Hi Alan,
Thanx for that quick response.
But i dont think you understood it, or i din't explane it very well.
I have a Midicontroller,…… and the MF and ND are in a rack.
I have 128 presets in my Midi pedal board, 40 Pres. in the MF, and 18 Pres. in the ND
If i select preset 41 on my Midi pedal board, i CAN do a Prog.Change in the MF and choose (for example) Pres. 12. No problem so far.
BUT the ND doesn't have Prog.Changes.
So, If i select preset 41 on my Midi pedal board, i get Pres 12 on my MF, and the ND doesn't changes. It changes only the First 18 Presets. (logical to me)
so i notice that the MF has a MIDI Program Change (send) Transmit Map
Quote. from Manual MF:
[XMT MAP] – Create a MIDI Program Change Transmit Map
In Bank Mode, when a Footswitch is used to recall a Preset, a MIDI Program Change message
can be transmitted from the MIDI Out jack or USB to control an external device (e.g. another
Factor series Stompbox, an Eventide Eclipse, an Eventide H000FW, etc.).
So i:
– Set the MIDI Transmit Channel  –  ch1 NovaDrive also at ch1
– i Create a MIDI Program Change Transmit Map  for example 13.1 (on the MF) = > 1(on the ND),   13:2 >2…..
– MIDI Program Change Transmit Enable – on
– MIDI Transmit/Thru Select – XMT
But it doesn't work when i select a Preste on my pedalboard.
ONLY, if i hit a Button ON the ModFactor (in bank mode), the NovaDrive chance to the desire preset.
greetings
rik
