Home › Forums › Products › Stompboxes › TimeFactor with other delay pedals › Reply To: TimeFactor with other delay pedals
#130265
davwood
    Yes, the only issue here is getting the other delay pedal to play nice with the timefactor, meaning being able to use the other delay with the Timefactor turned OFF. Everything else works just fine. Timefactor by itself….works fine. In all situations, no matter what type of set up (typical pedalboard chain, Timefactor on the end of the chain, other delay either before or after timefactor OR used in a switching system, other delay before or after…STILL GETTING NO EFFECT from other delay pedal). This presents itself even when i'm only running guitar-delay-timefactor-amp routing with nothing to get in the way. Both units, either on or off still passes audio no matter what the configuration is.
    Tried different cables yes, no change. Using lava cables, guitarcables.com, every type imaginable, same result. Using mono only.
