Home Forums Products Rackmount Sudden Pops and Crackles Reply To: Sudden Pops and Crackles
#130309
    Make sure your AC line voltage is solid – try running the unit off a UPS if necessary.
    Regarding your second problem – was the sample clock set to internal ? If so, it is a mystery, unless it is again a AC line voltage issue.
    Check for loose internal connections – with the audio output turned down but audible, lift one end of the unit up a few inches and then release suddenly. If you hear or see anything, contact support@eventide.com
