Home Forums Products Stompboxes Timefactor Boss FV-500H problems Reply To: Timefactor Boss FV-500H problems
#130438
    Do check the knob .. but also ..
    A thought occurs – if you control 2 or more parameters, you just get a 0-100 display. But, if you only control one parameter, you get whatever you programmed. It is certainly possible to program a high value for pedal up and a low value for pedal down. This would give the symptoms you describe.
