Home › Forums › Products › Stompboxes › Timefactor Boss FV-500H problems › Reply To: Timefactor Boss FV-500H problems
October 23, 2009 at 4:25 pm
#130441
The pedal calibrates automatically by remembering the lowest and highest position it sees. This is a continuous process.
You can sometimes get a problem if you have a rather "rickety" pedal and hit it hard, causing it to go to a point that is not reachable by hitting it gently – this will be remembered by the TF as a maximum, but will not be easily reachable in normal use.
