Home › Forums › Products › Stompboxes › Timefactor Mix Level in a Parallel FX Loop › Reply To: Timefactor Mix Level in a Parallel FX Loop
        October 27, 2009 at 7:27 pm
        #130466
When Killdry is ON, the Mix Knob acts as a volume control for the wet signal. (It no longer blends wet/dry.)
If you turn the Mix Knob to 50% with Killdry ON, your delays will be quieter than with the Mix Knob at 100%.
Your orignal dry signal level, however, will not change using the wetbox configuration you described.
