Home Forums Products Stompboxes midi Sync’ing Timefactor to Pitchfactor Reply To: midi Sync’ing Timefactor to Pitchfactor
#130492
I solved the problem :
I use Roger Linn Adrenalinn III as master midi clock source and from there signal goes to Midi thru box which splits signal to Timefactor and Pitchfactor.
now the effects sync perfectly, but  there is a problem with a looper sync. it goes of sync. It starts playback when i push play on my master midi clock device (that means it receives midi clock ), but it still does not stay on the midi clock for long.
any suggestions on that? or maybe its a bug?
thanks
