Home Forums Products Stompboxes Timefactor Boss FV-500H problems Reply To: Timefactor Boss FV-500H problems
#130497
I tried using it as gentle as I could, but the pedal really doesn't care, reaching never more then 99. In most cases this does not really matter, but if you for example want to use it on controlling the delay mix, it is quite annoying if it isn't 100% 100.. Any other ideas or should I just return the pedal?
