Home Forums Products Stompboxes Midi Control MF & TF Reply To: Midi Control MF & TF
#130624
achaput
    With the latest software you can program certain preset locations to Bypass the unit when called up via MIDI Program Change.
    In the System Mode of the slave pedal, enter the MIDI menu and go to RCV MAP.
    In the RCV MAP menu you will see a MIDI Program Change number on the left and the corresponding stompbox preset on the right. You can change the direction of the blinking arrow by pressing the left or right footswitch.
    With the blinking arrow pointing left, select the preset you want that will Bypass the unit.
    Then press the right footswitch to point the blinking arrow to the right. Turn the Encoder counter-clockwise until you see BYP. A setting of BYP means that the stompbox will go into Bypass when it receives that MIDI Program Change command.
