Home Forums Products Stompboxes Middle switch stops working randomly on 6 day old ModFactor!!!!! Reply To: Middle switch stops working randomly on 6 day old ModFactor!!!!!
#130700
This is a picture of a new switch and the right switch.
I encounter no problems when installing it.
You have to use a de-soldering tool because it is a double sided solder joint.
The solder traces are fairly durable but, you could lift one if you aren't very careful.
This is not a job for an amateur.
I highly recommend popping the top off the switch and cleaning it first to see if this won't fix your problem.
It did for me and no problems with it since.
If any one wants to call me I can walk you through this.
Of course eventide may not even post this.
They seem to have a problem with videos and pictures.
But if they post this my number is:
740 351 0402
USA
or email me at:
joeynorespect@roadrunner.com
Joey Ray
