Home › Forums › Products › Stompboxes › Pitchfactor MIDI control problem › Reply To: Pitchfactor MIDI control problem
December 14, 2009 at 9:35 am
#130761
I am making it work as it is, it's just more complicated, as I have to change the way my presets are set up to accomodate the change in the way the pedals function now.
On another note, are there recurring problems with the switches? The tap-tempo/bank switch on my PF failed for hours the other day. It would only let me scroll through the banks, and even then it was sensitive and wouldn't do it consistently. Any function that required it to be held (to enter setup or exit bank mode) didn't work at all. Eventually resetting the pedal seemed to help, but it's still not consistent.
