Home › Forums › Products › Stompboxes › Pedal Board for Eventide Stopboxes › Reply To: Pedal Board for Eventide Stopboxes
January 5, 2010 at 9:48 am
#130836
badmelonfarmer
No I am not using the supplied power supplies, I use some ones that I found that are flatter laptop style that sit under the shelf that the POD sits on.
this is what i use….
i use 1 per Eventide, with a OneSpot L6 Adapter… reverses the polarity and gives you the correct barrel size tip.
Cheers
BMF
