Home › Forums › Products › Stompboxes › Set Tap Tempo with External Pedal › Reply To: Set Tap Tempo with External Pedal
January 11, 2010 at 11:46 pm
#130894
That was the problem. I didn't press and hold the encoder and right footswitch together. But if I take the option: TAP < TIP , the footswitch didn't take over taptempo, but activate and bypass the preset.
is it only possible to tap the tempo in play-mode or is it also possible in the bank-mode.
