Home › Forums › Products › Stompboxes › Time Factor Tape Delay Setting – Saturation Control › Reply To: Time Factor Tape Delay Setting – Saturation Control
January 20, 2010 at 9:41 am
#130976
Then I hope you'll give the saturation control more reach in the next update! I use it in the loop, and I send it as high a level as I possibly can – just on the edge of power section overdrive. When I push the power section into serious overdrive, the TF will also overload. My amps are designed for mostly power tube saturation though.
With saturation on 10 I only hear a sliiight effect, with the effect on 100%. So, I'm wishing you'd give those of us who can't send a loud enough signal into the TF a piece of the cake too
