Home Forums Products Rackmount H8000fw 5.3 AES clocking problem >48k Reply To: H8000fw 5.3 AES clocking problem >48k
#131012
Siem
    -which routing are you using?
    AES8 8 Track AB
    -how clocking parameters are set?
    Source: AES 17/18 (does also work with 11/12 13/14 15/16)
    Sample Rate: 44102 / 48002
    ADAT (unlocked)
    FIREWIRE1 (unlocked)
    AES 11/12 OK
    AES 13/14 OK
    AES 15/16 OK
    AES 17/18 OK
    as soon as I go to another frequency that's not 44.100 khz or 48.000 khz it'll be like this:
    Source: AES 17/18
    Sample Rate: a strange number like 47891 or 47887
    ADAT (unlocked)
    AES 11/12 unlocked
    AES 13/14 unlocked
    AES 15/16 unlocked
    AES 17/18 unlocked
    -which AES connector(s) are you using?
    AES 11-18, the broad 'parallel-port' on the back
    -are you clocking the unit from internal clock….or from external?
    external, from one of the AES channels
