Home › Forums › Products › Rackmount › H8000fw 5.3 AES clocking problem >48k › Reply To: H8000fw 5.3 AES clocking problem >48k
January 22, 2010 at 2:02 pm
#131020
I have just tried myself here, with 2 units.
An H8000 connected to an H8000FW (both on 5.3) via AES_EBU on the DB25 connector, the one we advice and have available on the web store.
The H8000 is running at 96 as internal Master Clock.
The H8000FW runs on the same routing you reported and clock is derived from AES_EBU inputs 11 & 12- All AES 11>18 are clocked fine.
So, I can only think of:
-bad cable?
-CLEAR SETUP needed?
-something wrong in the computer/audio interface?
I
