Home Forums Products Rackmount H8000fw 5.3 AES clocking problem >48k Reply To: H8000fw 5.3 AES clocking problem >48k
#131026
Hi zoomex
we would appreciate details as this means pretty much nothing.
Do you hav clocking problems?
DSP x overload usually means the preset is too large or on the verge….running at 96KHz.
There may be some and we're trying to fix them…..and this is not the same problem reported in this thread.
So, here we go (again):
-OS running on the unit?
-name and number of presets you get this warning from?
-full description of unit I/Os, used routing and clocking setup
thanks
I
