Home › Forums › Products › Stompboxes › Anybody else getting a volume boost with the new software? › Reply To: Anybody else getting a volume boost with the new software?
February 5, 2010 at 1:15 pm
#131107
"The really weird thing is if you have a delay set up with the a/b mix
at 10:10, but have B set to no delay, you get a huge boost. This seems
to happen regardless of which mode you are in (digi, vint, etc..)"
Well of course, when the delay signal ends up on top, and somewhat in phase, of the direct signal you are effectively "summing" them. "No delay" in this case refers to time, not volume. You need to use the Mix parameter to balance or remove one of the delay engines.
