Home › Forums › Products › Stompboxes › Strange digital hum! › Reply To: Strange digital hum!
#131133
    TF has pretty good noise performance. But, if you give is a very low level input and then put a lot of gain after the output, you will hear noise. This is true of all equipment.
    Or, you could have a hardware problem, but this is less likely. If you think you do, try other cables, then try another TF (speak to your dealer ?), and if you are convinced it is your unit, contact support@eventide.com
