Home › Forums › Products › Rackmount › Eclipse Analog Outs › Reply To: Eclipse Analog Outs
#131238
Yes you can…IF you know how the Eclipse algorithms are made.
Series, parallel is not a problem.
Xfade doesn't make sense as you have two DSPs so you can:
-use the other DSP to switch to another preset
-build algorithms in a way that you can internally switch between parts of them (from a verb to a chorus, for instance).
best
I
