Home Forums Products Stompboxes [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active. Reply To: [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active.
#131261
    Not real clear about what you are doing – it depends entirely on how your MIDI map is set up.
    Make sure that you understand how these functions work – sounds like you may not.
