Home Forums Products Stompboxes [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active. Reply To: [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active.
#131263
caveman
    Are you sure you are sending the right PC?
    Some MIDI devices interpret 0-127 as 1-128, so the mapping might be off by one.. Have you tried sending 126 for bypass mode?
