Home › Forums › Products › Stompboxes › [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active. › Reply To: [RCV CTL] ? There are new choices for Receive Control to alter the unit?s BYPASS setting: ACT ? Make the unit ACTive, i.e. not bypassed. TOG ? TOGgle the between bypass and active.
March 3, 2010 at 10:22 pm
#131267
Awesome! Thank you so much guys!
The EFX goes from 1 to 128, the TF goes from 0 to 127!
So when I sent a PC 125 with the EFX, the TF actually received a PC 124, corresponding to the TOGGLE function! It now works great when sending a PC 126 with the EFX to make the bypass function work!
Thanx again
