Home Forums Products Stompboxes TF-With Catch up on, parameter control knob min/max values assignments don’t work Reply To: TF-With Catch up on, parameter control knob min/max values assignments don’t work
#131283
EdDrake
    As a follow up to my own post it looks like I'll have to turn off Catch up after all because if it's on I have to manually catch up the knob every time I switch to a new preset. I assumed since I have Global Mix turned on that once I caught the knob up it would stay this way even when I switch to a different preset but it doesn't. If Catch up is off my Aux Switch set to control Knob 0 works perfectly every time no need to tweak the knob.
    Is there any way to add this to a future update? Where Catch Up can be turned on but an Aux Switch Parameter Control Knob assignment can over ride this?
