Reply To: Modfactor Volume drop
Home Forums Products Stompboxes Modfactor Volume drop Reply To: Modfactor Volume drop
#131342
Jericho
Well I discovered what was casuing my problem…not sure what else is in your chain but maybe it will help you.
I am using a Radial Switchbone to drive a stereo rig.  The Switchbone has a knob to reverse polarity on the signal. (something to do with putting the amps out of phase as an option for a less focused, more spread out sound).
That was the cause of the trouble.  Anytime I had polarity reversed, the signal dropped from the Modfactor on Flanger/Rotary settings to almost no output.  Instantly came back when the polarity switch was set back to normal.
I don't know if that's a defect, something broken, or working as intended….but it least its diagnosed and I can avoid it.
Maybe something in your chain is effecting polarity and causing the same effect for you.
