Home Forums Products Stompboxes TIMEFACTOR + POWER SUPPLY Reply To: TIMEFACTOR + POWER SUPPLY
#131497
cacibi
    You need one EvenFlo for each Eventide Unit.  Takes up MUCH less space than even a single, standard wall wart however.  The only caveat is they get pretty warm and need to be exposed to properly vent heat.  So should be top-mounted somewhere on your board.
