Home › Forums › Products › Stompboxes › Time Factor melt down. HELP › Reply To: Time Factor melt down. HELP
        June 15, 2010 at 3:41 pm
        #131722
Obviously, the recommended approach is to return it to Eventide, especially if it is still under warranty..
Otherwise, the problem will be one of the following:
1) A broken switch. Hard to fix. Contact support@eventide.com and plead for a replacement.
2) Some dirt in the switch. Cleaning may help.
3) Bad soldering of the switch. Fixable.
4) A mechanical issue – may be fixable.
