Home Forums Products Stompboxes original power adapter delivering 12v Reply To: original power adapter delivering 12v
#131729
    mak:
    a 3rd party device rated @500ma will most likely easily drop from 12V to 9V under load
    Not necessarily – if it is regulated it may only drop a few mV. If it is not, its off-load voltage may be 15-20V.
    When using a 12V supply, regulation is the issue, as things inside a 'Factor start exceeding their ratings above about 15V.
