Home Forums Products Stompboxes Ground Control Tap Tempo Reply To: Ground Control Tap Tempo
#131740
steve.mastr
    Now this is really weird……..I set up the Ground Control to control the tap tempo via AUX SWITCH using the "momentary switch" setting on the Ground Control Pro. I get the exact same result – the tempo displays on the screen, but doesn't change UNLESS I turn tempo OFF……then I can tap the tempo in millisecond mode!!! Is this a glitch with the new firmware?
