Home Forums Products Stompboxes Expression pedals – any one better than the other? Reply To: Expression pedals – any one better than the other?
#131746
caveman
    I had used the Roland EV5 and the M-audio expression pedals, with results from both about the same.  Switched to the ernie ball and found the degree of control and stability is much better. When you take your foot off, it stays where it is without being accidentally nudged.. when you want to change settings, you can feel some tactile resistance there to gauge your travel.  Highly recommend this ernie ball 6181 Vp Jr. Active.
