Home › Forums › Products › Stompboxes › Factor – Inconsistent MIDI Clock › Reply To: Factor – Inconsistent MIDI Clock
        July 26, 2010 at 3:29 pm
        #131786
Sadly not – the input filter is a true lowpass filter on a changing numerical value – the output is a sequence of pulses – it is the timing that is the issue.
You really will have this issue with almost any MIDIclock generator (not just us) – if it does not work for you you'll have to find another way. Sorry.
