Home › Forums › Products › Stompboxes › Pitchfactor Expression Pedal Problem. › Reply To: Pitchfactor Expression Pedal Problem.
August 26, 2010 at 7:29 pm
#131898
I believe the M Audio has the cable hardwired into the chassis, but I'll check and swap cables. This issue was the big problem when I used non-recommended exp. pedals.
I'll also try the contact cleaner.
thanks
A
