Home Forums Products Stompboxes T-Rex Fuel Tank Chameleon – works for me. Reply To: T-Rex Fuel Tank Chameleon – works for me.
#131948
darrenw5094:
The Eventide TimeFactor needs 400mA when running on 12vdc. The T-Rex states on their Fuel Chameleon, that each outlet gives 300mA. Your two Eventides work fine on it, so is the mA on the Chameleon under rated by T-Rex??
This seems also the case with the Voodoo Labs  ISO5 Pedal Power.
For a regulated 12VDC,
the current requirement is 380mA at power up and 300mA in normal operation. Do not use unregulated 12V.
For a regulated 9VDC,
the current requirement is 500 mA at power up and 400mA in normal operartion.
I power all 3 factor pedals with the Trex Juicy Lucy, Each output gives 12v dc 300mA just like the Chameleon.
Never had any issue and each unit works 100%. I was recommended to not power anything else of the same Trex if im running all 3 factor pedals though so i only use 3 of the 5 outputs and have another Juicy Lucy for my other pedals.
