Home Forums Products Stompboxes Can the PF midimap a preset and be programmed to TOG/BYP/ACT the same preset??? Reply To: Can the PF midimap a preset and be programmed to TOG/BYP/ACT the same preset???
#132001
Ok,I understand that  and thanks but can the unit do what I asked
Can it be programmed to set a midimapped preset(IE when you map a PF preset to a midi program change) and can the PF then be set to be Bypassed/Active/Toggle the PF itself.
What I'm after is can I set the PF to load a midi-mapped preset and have the midimapped preset bypassable by stepping on the same footswitch on my pedalboard
The manual seems to say that you can load a midmapped preset w/ the ability to either have it switchable via BYP/ACT or Toggle BUT i can't get the PF to even allow this option during midimapping it can ONLY allow access to the BYP/ACT/TOG function if I don't Midimap
Which is it?
Thanks
