Reply To: Timefactor bypass via midi footswitch?
Home Forums Products Stompboxes Timefactor bypass via midi footswitch? Reply To: Timefactor bypass via midi footswitch?
#132159
Arvee72
Has there been any updates to address this?
Here's what I posted regarding this issue at HRI, Inc.:
Hey folks, need some advice on the "best" way to control my rig.
First, my rig:
Guitar -> RG16 (also used for channel switching) -> some analog pedals in loops 1-4 -> RG16 out ->
Mesa Mark 5 combo (dry) -> Mesa slave out -> Modfactor -> Timefactor ->
SS amp -> 2x Mesa 1×12 wet cabs.
Ground Control Pro midi out -> RG16 -> Modfactor -> Timefactor
GCP is set up for 4 Presets/8 Instant access
I have set up IA switches 1 through 4 to activate loops in the RG-16, no problems there.
I have set up IA switch 8 for tap tempo to Mod/Timefactor, no problems there.
Here's my dilema:
How do I set up, for example, available IA switches to act as a toggle ON/OFF for Mod or Timefactor where the IA switch in active "lit" mode means the Mod/Time is active. I'm able to get it the other way around, where "lit" = Bypass.
Ultimately, I would like to have preset 1 as my clean channel with no effects, then add T and/or Modfactor via IA switch(es) "stompbox" style just as I would add say an overdrive pedal via the RG16.
Hope this makes sense…
Thanks for your time!
