Home Forums Products Stompboxes trouble programming Xp pedal on Time Factor Reply To: trouble programming Xp pedal on Time Factor
#132200
    Better, but still not really clear.
    Presumably if you move the pedal to either heel or toe you must hear something. Although, when you say no effect, maybe you mean it's completely dry – this would suggest that the MIX knob is being controlled by the pedal – you should un-assign this knob (see User Manual).
    You also might want to consider re-initializing the unit, in case it has other mystery programming.
