Home › Forums › Products › Stompboxes › Ideas for Pitchfactor update › Reply To: Ideas for Pitchfactor update
November 30, 2010 at 4:06 pm
#132213
Hi Quintessence,
Like all the effects in PF, Crystals should already be able to trail off when bypassed by changing the bypass mode to DSP+FX. You can set this mode in the system menu. To enter the system menu, hold down the encoder and the right foot switch. By turning the encoder you can access all the different system options for the PF. Find the one that says BYPASS, and enter it by pressing the encoder. Turn the encoder until the screen reads DSP+FX, then exit the system menu by holding down the encoder and right footswitch. Now you should hear trails.
-Russ
