Home › Forums › Products › Stompboxes › TimeFactor MIDI Tap temp half what it should be?? › Reply To: TimeFactor MIDI Tap temp half what it should be??
December 6, 2010 at 9:48 pm
#132289
nickrose:
The TF should only respond to a MIDI value greater than 64 for tap, so it is as you suspect.
You'll have to either find a way to reprogram it, or tap a lot faster …
Rocktron said it can not be changed on the MIDI-Mate.
Any chance of an option on the TimeFactor to accept any value rather than any above 64??
Cheers
BMF
