Home › Forums › Products › Stompboxes › Time and Mod factor › Reply To: Time and Mod factor
December 10, 2010 at 12:32 am
#132323
Yeah, parallel loops can be tricky; they're definitely not as straight forward as series loops. I've had amps with both types, but as long as the loop was well-designed and built, either can and do sound good. With parallel loops, I usually run the loop's mix control (on the amp) all the way up when I'm using a modulation effect in the loop, but it depends on what sound I'm looking for, too.
