Home Forums Products Rackmount Relay Bypass clicking Reply To: Relay Bypass clicking
#132504
    Your pickup will probably have an output capacitor to isolate the DC – this is probably a bit leaky. You could either have it fixed, or put another one in series – given that you are feeding a high impedance input, any ceramic capacitor above 0.1uF should do the trick.
    Or, the DSP bypass can't be that bad, and it does avoid any tone changes between bypass and active. But, your choice.
