Home Forums Products Stompboxes Timefactor Touch Knob Sensitive Reply To: Timefactor Touch Knob Sensitive
#132526
Sic, that does work, but I have to either have the pedal in play mode or have an aux switch connected and set to tap. And while the delay time parameter is probably the biggest problem, I think this really applies to all of the settings, or at least the ones that have a range greater than 10. Anyway, this is just my take on it…
What if the proposed knob delay was adjustable or at least switchable (on/off)? Those settings could be placed in the utility section in conjunction with the new knob-lock feature. Just a thought…
