Home › Forums › Products › Stompboxes › Lovin’ the new firmare!! Got an idea for next one! › Reply To: Lovin’ the new firmare!! Got an idea for next one!
Well, right off the bat, lets say you have one of your presets set to looper. It would be nice to use the aux switches to control it, i.e., play/stop . If you have your switches set to 'bank down' and 'tap' it renders the looper useless (unless you take it out of preset mode). Maybe the exp. pedal could control these functions. I don't know, I don't use one….maybe I should. Also, I really like the 'hold' function and I can't use it with the way I have my footswitches set up ( 'bank down' and 'tap' ).On certain tunes it would be nice to say, for go the the 'tap' and use that switch for 'hold' instead'. Maybe all these issues could be solved if I just got an expression pedal…???
