Home › Forums › Products › Stompboxes › V3 Tape Echo Saturation Bug? › Reply To: V3 Tape Echo Saturation Bug?
January 21, 2011 at 5:55 pm
#132649
any fix for this? I have the same issue. All my tape echo saturation levels won't save right.
If I set it to 0 then save it, it works untill I bank up or down then if I come back to it the saturation is usually the opposite level and crazy distorted. it does however display the correct parameter, but the sound is way off.
So if I save it with a value of 0 and save the preset. I come back to it and the value sounds more like10 even though it displays 0. If i cycle the xnob all the way up to 10 and then back to 0 it works .You can save it, but soon as you bank up or down it is gone. anyfix or ideas?
