Home Forums Products Stompboxes Can’t set Q-Wah completely off with expression pedal controlling intensity Reply To: Can’t set Q-Wah completely off with expression pedal controlling intensity
#132686
wedelich
    Do you want to loose the touch sensitivity  and not hear the WAH filter modulate? Or do you actually hear a completely bypassed sound?  Setting the SENS to 0 on the speed knob will stop the movement of the filter, but will not bypass the filtering.  The WAH is a bandpass filter that starts at BASE on the xknob and moves by the DEPTH  amount.  So, even if you don't move it, it's still a bandpass at BASE.  The only way to bypass the effect completely is with the footswitch.
