Home › Forums › Products › Rackmount › Eventide H8000 : Trying to remote the levels and something wrong happens in the preset parametres › Reply To: Eventide H8000 : Trying to remote the levels and something wrong happens in the preset parametres
1) Which specific parameter(s) on Galaxy Borders changes ?
The soft key eq parameter low -18 dB :vary from-18 pedal up to 18 pedal down
If you change to another soft key :
With soft key reverse parameter Reverse t_lenght :13/16 note vary from whole note (pedal up to1/64 note pedal down)
With soft key mixer parameter level 1 vary from-100dB (pedal up) to-1dB (pedal down)
With soft key verb ,parameter level vary from-100dB (up) to-1dB (down)
2) Is it(they) underlined ?
The first key does come underlined eq and low dB -10dB also underlined in white.If you press reverse,then reverse becomes underlined as the reverse t_lenght 13/16 , the same for the 2 others soft keys
3) If you select this parameter(s) and press and hold SELECT, what do you see ?
Mode :off , Scale 0%, capture midi not thicked, range 36 dB,type absolute,low -18dB
4) What exactly happens in Black Hole/Majestic that is so surprising ?
-On screen in the soft key reverb,the parameter verb level -100dB vary from-100dB (up) to-1dB (down)
-in the soft key levels A OUT 1 wet/Dry vary from 0 %(up) to99% (down) A out 2 to oUT 8 do not change
5) What software version are you using ?
1 292
