Home Forums Products Rackmount Noisy H8000FW Reply To: Noisy H8000FW
#132844
    Yannis – you have to start believing me. Unless you can get most of the leds lit on a high signal, you will get noise. Whether a signal is present or not.
    This applies to all equipment, analog or digital, not just ours.
    My system is not noisy, because I operate it with the correct signal level. You'll probably find the problem in time, but if not, you should get someone in to look at it.
