Home Forums Products Rackmount Noisy H8000FW Reply To: Noisy H8000FW
#132849
    I'm afraid that, much as you may not believe this,  it is most likely to be your connections. If it were a problem in the H8000, it would probably not apply to all channels.
    But, if you haven't already, try a CLEAR SETUP to make sure something is not set wrong.
