Home Forums Products Stompboxes TimeFactor MIDI Tap temp half what it should be?? Reply To: TimeFactor MIDI Tap temp half what it should be??
#132855
badmelonfarmer
    literally got the Ground Control Pro home today from the US, hooked it up and programmed it….
    works fine as you would hope ie the tempo is correct and the "Repeat" function works with a single on/off press … you can set on of the Instant Access switches to the feature you want and then set the switch as a momentary latching as opposed to latching… bingo!!!
    tried a few mappings and all seems good.
    Only had an hour to play.
    Must say I am very impressed with the Ground Control Pro, it is surprisingly easy to set up and program.
    Finally VERY happy … now to program the names patch mappings etc.
    Much better / easier than the Rocktron MIDIMate.
